Abit AV8 Giving me some problems
Avengeance
Well I decided to go into my BIOS to tinker with my voltages a bit more and see if I can stable this thing out, because I was getting some problems. So I just checked the northbridge voltage and I pressed enter on it and it said enter a value 1 -3 and I was like wtf, it has never looked like that before. It would let me back out till I hit a number so I hit 3, and it came up at 31 volts... I was like GAH! so I pressed one and it came up as 11 volts. I didnt save it but why would it do something like that? Think the board might be going bad?
Holy geez - that's definitely a corrupt BIOS. I'd clear your CMOS, flash the latest BIOS and try again. I own the 3rd-eye version of that board, the default should be 1.50V without the 3. If the problem doesn't go away after a good CMOS clear and BIOS reflash I'd talk to ABIT, as it could be a hardware problem.
Don't worry, it's not really feeding 31.5V - pure physics, 31.5V doesn't exist on a motherboard!
I'd flash to the latest BIOS.
Also found these tips on extremesystems, you might try some or all:
TIPS
TIP: you have to disable cool n quiet when ocing
TIP: use slots 1&2 for BH-5, 3&4 for TCCD
TIP: if you have problems with winchester cores on this board flash to bios 1.5 or newer, 1.6 is recommended by abit
TIP: disable fast writes
TIP: with the XP-120 you will NOT be able to put anything in DIMM slot #1
TIP: use the ocz ddr booster in slot #2
TIP: VTT seems to need a reboot to "re-track" after a change
TIP: this board has a very flexible pcb and a very cheap plastic plate around the cpu socket, be VERY carefull with big heatsinks and dont fasten your heatsinks too tight!
TIP: if you cant get any higher make sure all parts of the board are cooled well enough, then start increasingvnb, vsb and vldt(vht)
TIP: if you can get any higher after that try to set vlink to 4 and the ht multiplier to 4x or 3x (800mhz/600mhz)
TIP: if you have a rev1.0 pro board (the revision number is printed on a sticker close to the cpu socket)
try bios 15 and lock the bus, if it doesnt work abit will rma the board
Avengeance said:
Does the DDR booster work on this board?
Says it has to be in slot 2 for some reason.
It was confiormed working there by a couple of oc'ers on extremesystems forums but not by me personally.
Alright so I did the other ones, but I have a few questions. What is the VTT? And for the VLDT, should I be increasing that by much? And should I be increasing the SB's voltage too? I didnt think that really needed an increase.
