Abit AV8 Boot Problem
Minimag47
Finished setting up my new system using an AV8 and when I went to boot it up I got the error code 26 on the onboard POST display. In the manual this code means:
1. If Early_Init_Onboard_Generator is not defined Onboard clock generator initialization.
Disable respective clock resource to empty PCI & DIMM slots.
2. Init onboard PWM
3. Init onboard H/W monitor devices
Now I have a slight idea what these could mean but no idea how to fix this. I pulled everything out of the system except the bare necessities. Currently the system contains:
Abit AV8
AMD64 3500+
Mushkin 3500 Level 1
Sapphire x800 Pro VIVO
Enermax EG851AX-VH
