Abit AN8 SLi
Haven't seen the Abit anywhere, even as a pre-order. The ASUS & the Gigabyte are out now, MSI...PROBABLY end of this month (keep on seeing a pre-order date at ZipZoomFly for two MSI NForce 4 boards pushed back every few days), the DFI is probably end of this month also, seen one or two places with a pre-order, one Canadian firm that ships to the USA saying 1/31 on their pre-order. Other pre-orders in North America that I've seen give no ETA on the DFI
Well, it's now June, & here it is . Please note that this is NOT the Fatal1ty board, but a vanilla version that includes a heatpipe for the NB... very sweet looking.
I've done a cursory search, & haven't found any reviews on this board yet available. I'm particularly interested because of the ABIT AudioMAX feature, which they're purporting will do Dolby Digital Live output...
Anyone have linkage to any reviews?
Not even any reviews on the Fatal1ty version about yet, that I can find. I'm personally more interested in the regla version, though... don't think I need the active RAM cooling ;)
Whats really the difference between the Fatality and the Regular Versions anyway?
Looks like the Fatal1ty's got active RAM, NB, & mosfet (OTES) cooling, whereas the vanilla version's got the heatpipe on the NB, & that's it. Prolly some other cosmetic differences as well.
Not much. On my AA8XE its just the OTES thing for your capacitors and voltage components. There are also no LED's on my version of the board. The PCB isn't red either. I also remember seeing more SATA connectors on the Fatal1ty version if I am not mistaken.
synergy321 said:
bah, dfi>abit
Not when it comes to quality, or stability.
USMC2Hard4U said:
Will the Fatality version of this mobo support VDimm of more than 1.8v?
Not sure on that one, my best advice is to look for an A8N-SLi Premium. Superior layout, should have comparable OC'ing. All around a better board. Its supposed to fix all the short commings of the Deluxe version.
I can't get over the terrible layout of that Abit board. I just noticed that it had the extra four pin molex for power to the secondary PCI-E x16 slot located on the bottom right corner of the board, the floppy connector isn't far from that. Terrible design work Abit. I suppose I could live with it if the performance and OC'ing were super badass on it. I am kind of doubting it having anything over the competetion though.
You're right, the placement of those 2 components is strange, but not a deal-breaker, imo. Practical? No, but not something I'd ditch this board over.
a. I don't use a floppy drive, & b. if you think about it, you're most likely going to have to run some kind of power into the back of your second video card, which means another molex connector at the end of that chain isn't out of the question.
**EDIT**
Not to mention that the two prices that I found for the A8N SLi Premium were both $300 :eek: :eek:
**EDIT**
The way I have the power done on my current setup would make that impossible for me. I have two dedicated PCI-E graphics power hookups and the 12v 4 pin molex doesn't reach down quite that far. Sure I could do it with an extension and still keep it looking neat, but this board would have to really have something over the A8N-SLi Premium to make me want to switch.
I'll probably replace my Deluxe with the Premium when I find one.
