Abit AN8 SLi Boot Issue
Bugbear
So last night I put together my system. By 10:20pm I was able to hit the "power on" button. Nothing came up on the monitor and the mobo made 1 long beep followed by 3 short beeps. I figured that this was a problem with the video card. I was too tired to think of a solution and trouble shoot. So this morning I am thinking that I need to have the single 7800gtx in the other pci-e slot. Does that matter? I am at work now and the abit-usa.com website doesn't have the user's manual available online. I do have the "Normal vs SLi mode" chip set to "normal" on the mobo. I am not too sure about this chip. Is it supposed to snap into place? It seems kind of loose. The 2 clips on the side are holding it, but it never snapped in. Currently the video card is installed on the pci-e slot that is closest to the cpu.
Here's a link to an image of the mobo:
http://www.abit-usa.com/products/mb/large.php?model=275
In this image the sli chip is set to "SLi mode" but on my system it is in "normal mode."
FYI:
I have the 3 power connections to the mobo.
2 CD/DVD Drives
2 Hard Drives
1 Floppy
1 PCI soundcard
1 TV tuner card
I forgot to mention that once it gives the error beeps, it shuts off in about 3 seconds. I am almost 100% sure that it's a video adapter issue. I just need to clarify if it matters on which pci-e slot it is installed on. The mobo is an SLi and also has the SLi vs. Normal chip that I mentioned before. Thanks.
MAke sure you plugged in the aux power to the card and the aux power to the board. Alot of people for get the two
You supply should have a 4 pin square 2x2 molex for your board in addtion to the 6 pin black interface for the card or at least an adaptor. Your main should be 24 pin or at least a 20 to 24 adaptor on the end
The mobo actually has 3 ports for power sources. I have connected power to all three. There's the large 24 connector, the 2x2, and another 4x1 (same power connection of a cd-rom drive). The mobo lights up when I power on.
