duncman737
- Apr 20, 2006
Any build data appreciated for this sweet new board!
sniperchicken said:HARDWARE
MOBO: Abit AN832X
CPU: X2 4400+ (260x10@1.500V)
MEM: 2x1024 Mushkin Extreme Performance DDR500 (3-4-3-8-1T)
HDD: 2x74GB Raptors(RAID0), 1x160GB SATA, 1x320GB SATA
GFX: 2xBFGTech 7800GTXoc
SOUND: X-Fi Platinum
PSU: PC Power & Cooling 510W SLI
shipped bios: 10
current bios: 10
PROBLEMS DURING BUILD:
1) After installing all drivers, Device Manager still reported Unknown Device.
2) Uninstalled chipset drivers trying to fix the Unknown Device problem, lost "nvcchflt.sys" and system would not boot into Windows.
3) Serious Sam 2 crashes within 30seconds to an hour of playing.
SOLVED PROBLEM BY:
1) Unknown Device was the "uGuru" garbage from Abit, installed program, Unknown Device was installed, uninstalled uGuru and device reports "Unable to load drivers", reinstalled software again and just disabled on startup.
2) Downloaded (if you need a copy pm me) and used recovery console to replace file.
3) Unresolved
CURRENT STATUS:
Prime95 solid on both cores 24 hours (small fft) with 3dMark 2001 demo looped.
3) Serious Sam 2 still crashing.
