Abit AI7 stop at Postcode 9.0, not boot
peterja88
Hi
Please support with my new mobo
just bought a brand new MB AI7 for test,
Get problem to boot, stop at Post code 9.0 (Bios take over booting job)
Tried with clear CMOS (change key from pin 1-2 to 2-3 for several minutes, with power cord off + lithium battery off 30 min)
Read all forums I know without any certain tip I could try, except the CMOS + power off min 30 min
Any known issue? or easy solving trick
Any senstitive hardware to check, unconnect first ??
Had to give my ram a volt increase for it to do the first post. Try to go up to 2.7 range see if that works. Believe it was like at 2.55-2.6 when I started up. Hope that helps
