Abit AB9 QuadGT issue?
JucyTEC
After i came back from a business trip i'm seeing the following:
Turn the computer on... Turns on and before it POSTs it shuts off...
Turn the computer back on... Turns on and POSTs and shuts off...
Turn the computer back on AGAIN and it gets into Windows and eventually shuts off.
When it's in Windows and it shuts off, it looks as if the system was told to shut off. The screen dims and as it attempts to shut down properly it is forced off.
So... I did the following:
1. Change the PSU from 550W to 650W
2. Change Video Card (found a blown 6.3V 1000 uF Capacitor)
3. Remove the power button and tried shorting out the pins to start the computer.
4. Pray on the computer.
5. I've visually inspected at all the Capacitors on the Mobo. All seem fine.
6. Strip all components to the bare minimum and boot.
I have NOT ruled out the following:
1. Motherboard
2. CPU
I have overclocked in the past... but was under clocked for a long time... Got lazy...
Anyone ever have similar issues? If so what was the resolution? Or could someone make another suggestion?
If not i have to replace the motherboard.!
it definitely sounds like a cpu issue, but have you tried clearing the cmos? take the battery out for a few minutes
Sounds like cpu if you have another board or a buddy with one you should test it out so you can get it rma'd
