Abit 865 Chipset Boards
kockblocker1
Hey guys I need some help from you intelligent [H]ers on a motherboard selection. I’m starting to get pissed about the problems I have been having with this eVGA 6800GT and my Asus P4PE. It’s time to just get a new MB already. Price is an issue but I do want to stick with an Intel chipset so I am mainly looking at the 865 boards. I also want to go back to what has always worked great for me, Abit boards. Not that Asus sucks because it certainly doesn’t, its just that I have had great luck with Abit boards in the past.
Here is my current setup:
CPU: 3.06 P4
Ram: 1gb PC3200 (2 sticks of Kingston 512mb chips bought 6 months apart)
Video: eVGA 6800GT
Sound: Soundblaster Live MP3 with the Live Drive
HD: 80gb WD IDE x3, 120gb WD IDE x2 (2 80s are RAID 0 and 1 80 is for Windows)
IDE RAID: Promise Tx2000 PCI card (the P4PE didn’t have IDE RAID onboard so I got the card)
CD/DVDrw: Plextor Premium 52x, Generic 8x DVD
Powersupply: Compusa 550w (just got it 2 weeks ago)
Case: Antec Full Tower
After looking at the available boards on Abit’s site I got confused as to which is newer, which I’m guessing also means better, than the next.
Here is a list of choices they have:
Abit IS7-G
Abit IS7
Abit IS7-E
Abit IS7-M
Abit AI7
Abit IS7-E2
Any help would be greatly appreciated.
1st: IS7-G/IS7/IS7-E/IS7-M
2nd: AI7
3rd: IS7-E2
Newer doesn't mean better, but the newer ones might have Prescott support. However, since that isn't a big concern, the AI7 is nice, but if you don't want the uGuru stuff, skip it and get the IS7-E if you don't require GbE, firewire, and more than 2 SATA ports.
bah unless you want to volt-mod your board go with the Ai7
dont expect to overclock on it past 260fsb 1:1 from what ive heard
it is one hell of a board though, and gat is sweet
the only problem i had with my ai7 is that it didnt want to go much past 200 fsb 1:1 in dual channel...i would get weirds artificating in doom 3. i was 2 sticks of kingston hyper x pc4000, so the memory should have been up to the task...
take one stick out and everything was perfect... :mad:
I went with the AI7 from zipzoomfly. $105 retail box. I wonder what I can get out of my 3.06 proc and cheepo kingston value ram.
I've got an IS7 and had 0 problems with it. I don't over clock it but I've read about plenty of people using it as a decent over clocking board.
Don't make a mistake and buy the IS7-V ... some places list it as having an Intel 865PV chipset, when in reality it is an 848P board.
I burned up my IS7 with condensation. I replaced it with an AI7. The AI7 is a much better board IMO.
Looks like I'm getting me some ram too. :)
Corsair TWINX1024-3200 1GB Kit DDR400 XMS3200 Dual-Channel Memory
I've got an AI7 and it would clock my 2.8c (30-caps) to 3.7Ghz (270fsb) @ 1:1 w/no problems. Voltages are solid as a rock too. they usually only fluctuate +/-.01 or .02v.
You don't have to use the uGuru stuff either...I think it's gimmicky...and I don't use it. MBM5 supports the AI7 just fine with less overhead.
Even though you said you wanted to stick with Abit, I think you should also take a look at the Epox 4PDA2+. I've been considering selling my AI7 and getting that Epox board.
I use to have an IS7-G and loving it.
Sold it to my friend and he was able to oc my old setup (1.6A Northwood) to 2.4 with the IS7-G rock solid.
These boards have known issues with memory based on winbond CH-6 modules, which the XMS3200's are. This problem has not yet been fixed in a BIOS update, and probably can not be either.
I changed to the Corsair XL RAM and the problems went away. This is because the XL's are based on Samsung's TCCD chips.
If you still have the memory on order, I suggest that you exchange them for the XL's
