AB9 QuadGT and Memory Volts?
bass_ec
I'm really really lost when it comes to mobo specifics. Noone has clearly layed out what the pros and cons are for 650/680 platform vs the 965/975 platform, which is kind of frusturating. However, I recently picked up an AB9 QuadGT based on the stellar reviews I've heard about it, and knowing that ABIT makes some good products.
Now, my memory calls for 1.9v, where as my mobo says "Notice: Only DDR2-800 memory supporting JEDEC approved 1.8V operation with timings of 5-5-5 or 6-6-6 is supported on Intel Desktop Boards based on Intel 965 Express Chipsets." based on Newegg.com's site. Is it as simple as pushing up the volt by .1 on my mobo, or am I missing something? I'm also unsure as to what "voltmodding" is.
I'm just completely lost when it comes to these specific things...:(
Is that an easy fix? Is this what volt modding is?
Yes it is an easy fix and no that is not what volt modding is. Volt modding is physically modding the board to allow for much higher voltage settings. What I just said is doable in the bios no modding required.
