I made a HUGE mistake recently. I really wanted to replace the coolers on my cpus because they were so damn loud. After removing the mobo, I discovered the backing bracket specific to my old cooler (which had to be removed) was attached with super-adhesive doublestick tape.
I thought maybe I could pry it off -- but in so doing, I hit a motherboard trace (actually several).
The hopeless question is... if I have scratched a trace or two -- the mobo is basically dead, right?
The more nagging question is... HOW THE HELL do you remove double-stick tape? Why do they even use it? It was like superglue. Thank you Thermaltake for making it IMPOSSIBLE to change out a cooler.
If anyone has comments (other than "you dumbass") please share.
