AAAAAAAAAAARGH stupid pc, help me!!!
Thermite Paste
im tring to install a 56k modem on a friends pc i built for him (yes, he still uses dialup). so every single driver for the damn thing i downloaded wont work. like i het the setup icon in the file and i get an hourglass for a second or two, then NOTHING happens. hes running 98, but i got the rite files for teh operating system. it was working fine before i had to reformat due to a sound problem, and these are the exact same drivers i downloaded then. WTF is going on?? I am so pissed off and aggrivated at this pc, i might make a pipe bomb and blow it to hell if i dont get it fixed.
Have you tried extracting the setup file and installing through the Device Manager?
yea, it was a zip so i extracted it into a folder, and thats where the setup file is. ive tried going into device manager and using it as a specified location, but it still doesnt work.
Papa-Ming said:
Try this. Physically uninstall the modem. But unistall the modem drivers to if they're there anywhere.. before shut-down. Reboot> letting 98 do it's thing with assigning IRQ's. for the sound.
Shutdown again, put that modem in another avalible slot. reboot.
Just try that.
tried it, but it didnt do anything. same problem :(
i re-downloaded the driver, and it just mysteriously started working. thanks for the help guys!
