AA not working with NFSU
  • Thread starter Deleted member 68403
  • Start date
D
Guest
I bought NFSU today and installed it. First things first. I downloaded and installed the latest patch. After maxing every setting possible I loaded it up. I play games using the system in my sig. I run 4x aa and 16x af in the nvidia control panel, but when i play the game, AA is clearly not being applied. Any ideas on how to fix this? Thanks in advance.
if you have blue enabled (at least i think it was blur) then aa won't work.
it might not be blur, but its some kind of visual effect.
Brent_Justice said:
disable motion blur and light trails and then AA will work in the game
Thanks Brent, that fixed it :)
personally i'd rather have blur and light trails as opposed to AA.
lol that game flies on my geforce 6800 gt , in the menus its hard to switch between different options cause it just so fast ... ea sux they do all those console ports :mad:
