AA Battery Charger
antok86
can anyone recommend a good AA battery charger. i use alot of AA eneloops.
thanks
I don't know if its good or not, but I bought the Eneloop charger w/batteries on amazon.
Maha C9000 or the La Crosse BC900 should be at the top of your list. Both are a bit pricey, around $50, but worth it. I have the Maha and it's been rock solid for over 2 years.
+1000 on the Maha, I have the same and it is worth it:
http://www.amazon.com/Powerex-MH-C9...USLM/ref=sr_1_1?ie=UTF8&qid=1338905666&sr=8-1
Thomas Distributing is very good and also is a great place to buy batteries also. I have used the MAHA batteries with no problems:
http://www.thomasdistributing.com/Maha-Powerex-MH-C9000-AA--AAA-Battery-Chargerbr_p_134.html
Eneloops and the low discharge Maha batteries I use:
http://www.thomasdistributing.com/N...AA-NIMH-Rechargeable-Batteries-4-Pk_p_21.html
http://www.thomasdistributing.com/-...rgeable-Batteriesbr-Low-Discharge_p_2252.html
does the lacrosse come with a 8 cell charger rather than the 4?
