destroyer159753
- Mar 16, 2003
Edit: Solved! I think lol
I recently upgraded my sysem from an athlon xp 1600+, 768 pc2100 and biostar m7vib ( i believe) to an athlon 64 3700+ san diego, asus a8v (non deluxe edition), 400 watt power supply, 1 gig x 2 rosewill pc3200 in dual channel, windows xp pro sp2. A few weeks ago I was doing some graphics work in Bryce and tried to render it but was taking too long/was unresponsive, so I Ctrl-alt-del'ed it and closed it, 10 seconds later the system locks up, mouse and keyboard unresponsive, I attempted to restart with the left switch on my case beliving it was the restart button, then it goes into some weird power saving mode, so then I decide to turn it off with the power switch for 4 seconds. When I boot back up, the monitor gives me its ok message, then says "Power save." I restart because everything is unresponsive and didn't post, now the monitor light is just orange, no post. I then reset the cmos via unplugging battery, and it works perfectly, and I just thought that the problem was the crazy left button. Today, I tried to start up system like normal same thing, wouldn't post and reset cmos worked, and then later system froze for no reason, but this time I disabled all acpi crap in the bios thinking its the power save mode being crazy. About 10 minutes later in windows, it freezes again, this time I disable acpi and cool n quiet, again later it freezes, and now I'm stuck on what to do, very frustrated that my new computer isn't working. Any help is greatly appreciated.
Add: Just now I attempted to reset the cmos, but it didn't boot up, so for some reason I decided to check if the memory was the problem, I took 1 stick out (i checked manual to make sure how to have only 1 stick in) and then it booted up, I then swapped out the stick for the other, again it booted up, I thought it might be dual channel being the problem so I put them back how they were originally, it booted up, I then ran memtest86 on one stick, got several errors in the first 10% of the test, I ran the other stick, no errors! I'll have a little talk with Rosewill about getting me a new stick..
