A8V forgetting BIOS settings?
denaps
greetings,
i have an a8v with a 3500+. i have 2 internal HD's - one maxtor 60 GB ata, and one seagate 160 GB sata on the internal sata controller. i set the SATA drive to be the boot drive in the bios, which normally works fine. however, after the machine is off while i am at work, i come home and turn it on only to find out that the BIOS has reverted to the maxtor drive (which doesn't have an OS) and the machine won't boot until i re-assign the boot drive (to the VIA sata controller) in the BIOS. after that, it boots fine until the next time i turn it off for more than 12 hours. it keeps forgetting the boot drive settings, but it does retain all other settings?! i don't get it...
is anyone else experiencing this problem? should I just hope for a BIOS update?
jeff
Try removing the motherboard battery and letting they system dump all CMOS data. If it continues try replacing the motherboard battery.
