Hey guys, I just set this up and was wondering if anyone can help me? Yeah its a little old, its suppose to tie over over until Windows 7 is out.
So I set this up last night and is having a little problem getting over 270FSB. The computer posts, boots, and primes fine at 265FSB and stock voltage. When I get to 270, it won't post reliably, it'll post maybe once out of 3 times I try. When I do post and get into Windows, it primes fine and stable.
I tried upping the voltage on the CPU and upping the voltage on the Northbridge, it helped a little but still doesn't post reliably. I was fooling around with the settings so I know the CPU is stable up 290FSB if it does post and gets into Windows.
My settings right now is:
CPU ~1.4V(that's what CPUZ tells me anyways, the voltages jump around a lot on this board)
memory divider 133
last stable FSB is 260
HT is running at 6x
NB voltage is 1.6(opposed to 1.5)
I'm running a new PSU with it right now, a BFG GS-550, should be more than adequate. Otherwise everything else is same as in my sig.
Can anyone help me hit 2.9Ghz or even 3.0?
memory divider 133
HT is running at 6x
