A8V deluxe, enable pci/apg lock...
Xenozx
Has anyone successfully added the agp/pci lock on the A8V? If so how do you do it and what BIOS revision do you need? i currently have rev 1006(1005.xxx) please let me know any info you might have in reguards to this.
I also wonder about this.I never tried it though.Really no big deal to me since im using a fx-53 and am completly satisfied with how everything performs.But if that feature can give me better performance then i have currently then i will give it a try.
It looks like you need to get beta version 1005.20 or 1005.21 for this feature to be available. I managed to get my 3500+ to 230x11 or 2.53 ghz without a problem now that i can lock my agp/pci. I idle around 30 degree's C and load at about 43 degree's C. I probably can go further but im happy with my overclock and ill leave it at that until i get my new videocard, then ill judge if its worth going further. I prime95'ed for about an hour with no problems. never went over 41 degree's. will continue prime95 when i have more time.
benched 3dmark2001 at over 21000+ points and pulled a 5000+ pcmark2004 score with my 9700 pro. pretty happy considering im in the top 20 of the athlon 64 processors including fx53's in pcmark2004. When i get my bfg 6800 ultra my machine will be the king of the hill! yeah!!!!!
ok ill throw out one more qestion. my mother board has a 1000 mhz hyper transport rate (2000 effective). considering im overclocked to 228x11 currently it should be alot higher (2456 i believe). but when i go into sandra to check it it say its at 2x912 (1824). any idea how to correct this and get it back to its higher #? this would give me more performance correct? any ideas how to get it to atleast default if not the overclocked ammount?
asus a8v
3500+ 228x11(2.51)
slk 948u HSF
Tachyon G9700 pro 128 mb
3200 ddr corsair 2-2-2-5 mem at 456 mhz at 2-3-3-6 timings.
520 vantec stealth
2 sata baracuda 120 mb 7200 rpm 8m in raid 0 config.
i don't think the motherboard can handle 2456mhz hypertransport which is why it backs it down. 1824mhz is more than enough HTT. HTT barely affects performance at all. you could probably knock it down to 600 and you probably won't see a difference in performance.
in fact check out this thread...http://www.xtremesystems.org/forums/showthread.php?s=&threadid=39559
the guy that did the tests received higher 3dmark scores at 400HT than at 1000HT
kool, well that answers my question. I do score a heck of a lot higher at 2.5 ghz with 2x912 then i did at 2.42 ghz at 2x1200. guess ill leave it be. thanks tho.
That makes no sense.Latest bios is 1006 so why would an older beta have the feature,and not the newer non beta?
ok well it all over the net but i will give you the answer. There is a incompatability issue with fx-53 processors. therefore until asus fixes this they are not going to include it in the bios versions on their website. the beta ones listed above where released with the feature. then every version after that it was removed and it will stay that way until the problem is resolved. i have a 3500+ so its not biggy for me. Do a search in google and you will get a more descriptive answer. Do a search on these forums for "Criton" and it will link you to some information about it as well.
