OK i bought an asus a8v and a 3500+ a while ago. Its pretty much worked fine. One problem that was always there was
if the computer was off and you turned it on, it would turn on to nothing but a blanks screen. You then had to hit the reset button and then bootup would come up as normal.
problem 2 was that on every boot for the most part it would say overclocking failed. please press f1 to enter setup and fix. if you entered setup and saved and exited (didnt change a thing) it would boot into windows perfectly fine and you could prime 95 all night. If it passed this step it automatically changed the voltage on the processor to 1.8v+. and you had to reboot. if you restarted it would boot up normally no matter what this only happends on a fresh turn on.
anyway now im getting constant reboots. I was sitting here playing fable. I had my computer set to shut the monitor off every 30 minutes. So after about 30 minutes the monitor would go off and eventually it would pop on and reboot the machine. then it would go back into windows and the same thing would happend just a little bit sooner, then again even sooner. Anyway i decided all these could have been because of a beta bios that had the agp/pci lock which is why i used it. finally decided to go with the newest beta bios listed as august. After bios install i got checksum bad error message. went into bios and fixed everything back to normal. rebooted and fine. Then reboot out of no where in like 5 minutes. then it came up and said something about "speedfan could not be exectued because of something in the user.ini" anyway another reboot and booted back up no longer got that error and speedfan opened right up. i did change the voltage from 1.525 to 1.575 now ive been able to type this whole thing without a restart. im at 215x11 at 1.575v im usually at 230x11 at 1.650 without a problem, but im not gonna be able to go there anymore with this bios since it doesnt have the agp/pci lock.
anyway any idea why i would get reboots like this. Temp is not an issue, even at 1.8v i boot up at 42 degrees c. im at 1.575 now and its 32 degrees.
ok finished typing up to the text above and then another reboot only this time it was a Blue screen of death. basically talking about new hardware, etc...
any idea's?
no hardware has been changed in quite some time...
any idea's?
