A8V and a 3000+
Mr.Pickles
well I have as in the title a A8V and a 3000+ and I want to start ocing the pig. The proc is a Venice core and I am using a Zalman 9500 wich on a preset OC of 17% (1.8 now 2.1) is running at 25C/77F idle. THe real qestion is has anyone used this mobo and proc and Oced the only thing that I am mad at is because it is a little diffrent than my old soket A 1700+ which saw a 1.4 to 1.8 (I was too afrad to go any further on that TT volcano.
I've got the A8V Deluxe, and I'm currently running a Venice 3000+ at 2.25. I could have gone further if I had better RAM, but Corsair value ram tends to get finicky after 212MHz for me.
Key thing...put that AGP lock in gear in the BIOS! I fried a video card learning that. :eek:
alf what are the V core settings you are using because I can loosen my timings to go a little further than you I also want to know what all the other settings are and want to know how to lock it (the AGP).
The AGP lock will probably currently be set at Auto. You'll want to change it to 66/33.
You'll have to fool with the ram divider. I suggest getting CPU-Z and using it to test what your ram clocks are, as the ratios don't seem to be accurate.
I haven't changed the voltage settings from auto.
