A8r-mvp
pk-w00t
My voltage is locked at a max of 1.4V. I have the latest bios updates and from what I've read throughout these forums, other people with the same processor (AMD X2 +4400) it's not a processor problem. I'm curious if it's the motherboard, and if so, is there any way to unlock it so I can bump it up?
right now there is no way to up your vcore, this is a huge problem for alot of people wanting to overclock and is completly different from the review bios used for AT.
You can visit AT's forums for more info. the PWM circuity is cheap and cant handle the increase in higher settings so asus will not support a new bios with "unlocked" options at this time.
you can enable "vcore overdrive" or whatever for .07 increase to vcore which will help a little bit.
