superkdogg
- Oct 14, 2004
OK, here's the story.
I got home and looked through my electrical junk. I find out that I only have a 5K fixed and 10K variable resistor to do the vMod from the vr-zone's guide. I thought to myself and did some math. 15K total resistance was about what I was going for anyway, so I set the 10K to max and soldered the two together.
In forethought, I went to my comp pre-mod and set it to 7x200 with 1.150 vcore so that if the mod worked, it would boot with about 1.45-1.5. After a reboot to ensure that this worked, I started taking stuff apart to do the mod.
The soldering went kinda bad, my hands were shaking (nervousness-something I didn't have in my practice solder joints), but eventually I got it soldered. I turn on computer and it seems to be working. On the first boot, I got 1.44 vCore with the 1.150 setting-just what I wanted.
So I started cranking up the vcore through a series of reboots. No matter what I put in the bios, the vcore stayed the same @ about 1.44. I didn't know what was wrong, but at this point I decided to cut my losses and give up. That was a bad idea. When removing the mod, a little piece of the board's resistor(?) [the thing that I had soldered to]- came off! So now the thing is like 3/4 there, but I can see a little bit of the solder pad on the motherboard where it connects. Right then I thought it was junk, but I continued removing the other solder point which happened without incident.
I put stuff back together and I tried to boot. To my amazment and joy, everything fired right up. So, being really sure that vmodding was something better left up to the experts, I was ready to put away my iron and call my Winchester running @ 2.7 a day. Forget about 2.8 if I could get to 1.6 or whatever. I put everything back in the case, stand the case up (it was lying flat with the mobo on the tray while I was soldering) and plug everything (usb's, keyboard, vid card) back in. All I get is spinning fans and hard drives spinning up. No video-bad sign.
I tried resetting cmos multiple times, with power cord unplugged and even left the jumper on when I went to bed to no avail. Either the motherboard or cpu is not functional, because everything else works except there's no display and I can tell by listening to the drives that there is no attempt to boot Windows.
It acts exactly like a motherboard that's grounded incorrectly, so when I get home I'm gonna see if it's possible that something is grounded that should not be. What else can I check before I call it hosed and order something else that I'll be more careful with?
