A8N32 - Windows XP Pro stability question
stehle
I can honestly say I'm at wit's end with this MB. I've never had such a difficult time getting my machine up and stable--not even when I put Win95 on an old Gateway cpu. :(
/rant off
After some help from a friend (and these forums), I finally got my computer up and running. I did have some issues installing Win XP Pro on my SATA HD, but I finally got that sorted out. I have updated all the drivers (ASUS install CD, nVidia). My BIOS is updated with 1009 and everything is set at default.
The problem I run in to is WinXP Pro will just randomly shut down (sometimes it won't boot, other times it will last 10 minutes). Occasionally Windows will want to send an error report. Usually it has to do with a "device error". I am totally stumped as to what could be causing it. The device manager shows nothing amiss so I'm not sure if that is the problem.
The PS is, from my limited understanding, rather beefy. Everything on the board is powered (except the EZ_PLUG because I'm not running dual GPUS). It almost seems the cpu just resets when there is any type of load on the HD or processor. Should I be tweaking anything in the BIOS with regards to the PS?
Any advice would be appreciated.
latest error
Hardware failure: contact original computer manufacturer
Thank you for submitting an error report.
Problem description
The error was likely caused by an unrecoverable system hardware error. These errors are general in nature and can be caused by problems (such as overheating) with one or more of the following computer components:
Random Access Memory (RAM)
System board
Central Processing Unit (CPU)
Power supply
Sorry for all of your problems. I've got the same motherboard and it's was the smoothest build I've ever done. Only one BIOS setting I had to track down that was causing me problems in some games in SLI.
Try running this diagnostic tool: http://oca.microsoft.com/en/windiag.asp
I don't recognize your power supply brand. It should have enough power, but if the memory diagnostic checks out, it would be the next place I'd look.
Good luck!
I have the same motherboard, its rock stable but I am using the Corsair 3500LL memory. I think this board is pretty memory specific.
Good luck!
I think I have found my problem. I ran the diagnostic tool and I found error after error in the memory. I took out the first gig DIMM and then re-ran the diagnostics. No errors. Looks like it is time to return the OCZ and get some Corsair.
Words cannot express how happy I am to have this solved. Thanks very much. If you are ever in Boston, I owe you a pint.
