A8N32 Vcore issues
Hordsak
Hi, I just recently installed my new A8n32 SLI and an 3800X2 CPU. For some reason, I can't get a vcore of over 1.44 unless I use the +200mv setting, and I don't want to use it. Even if I set the vcore to 1.55 or any setting above 1.425, it always stays at 1.44. Thoes readings are acording to the HW Monitor in the bios, and Asusprobe as well as CPUZ. Could it be a limiting problem that I'm using an Antec 430watt true power? I have 1 HD, 1 CD, 7800GTX, 2x512, and 3 fans running curently. Bios is verision 703. Thanks.
Software monitors cannot be relied upon. Also Vcore fluctuates depending on how much the processor draws. If you overvolt and underclock it draws less power than when you undervolt and overclock, despite the second having a lower Vcore BIOS setting.
