About 6 months ago I built the rig in my sig at the setup went very smoothly and I had absolutely no problems. I wanted to reformat and reinstall windows so I did so and ran into many problems.
I reformatted my rig today and after the reformat was done windows setup automatically does a system scan restarts the computer. When the system restarts it gives me a BSOD saying my system is not fully ACPI compliant bla bla bla, press F7 when you are promted to install third party disk drivers during setup to disable ACPI. I did this and it gets rid of the previous BSOD, but at the expense of disabling ACPI which is unacceptable.
Now, it gives it a different BSOD at the same point in time saying that there is insufficient memory or disk space. It also says that if the hex stop error message points to a device driver then it says to try a different video adapter.
Any suggestions? When I first built the system I updated the BIOS to the latest version to clear up some issues I was having with BF2 and FEAR. This is very frustrating.
