A8N32-SLI - EZ-Plug verification?
madmalthus
Hello -
What is the quickest way to verify that the EZ-Plug on an A8N32-SLI Deluxe is actually working? I have reason to think it might not be working but I canot verify...
Any help appreciated.
Check on asus probe with the voltages its showing and if they are within the range -+5% then they are right. You are best checking on the BIOS , it should be in there to.
The EZplug is used for sli but most people dont have sli and it becomes quite useless.
What is the problem you are having ?
Check the rails with multimeter.
Thanks, I will check PC Probe & BIOS.
Here's the problem. I dropped a "firefly" into the EZ-plug. Dumb idea. A firefly is a tiny LED device that fits into the male Molex connector and lights up when it gets power. I thought it would look cool, you know.
Anyway I powered up and I noticed the firefly wasn't lighting up. So I decided to take it out. Probably another bad idea. I had to pry it out, stressing the EZ-plug, so now I am paranoid that I may have broken it.
I run in SLI mode (the cards don't have their own power inputs) and haven't had any stability issues so hopefully it's fine.
I appreciate your help.
Glad to be of service to you , if there is anyhing else i can help you with just send me a pm. Cya and take care
the red LED somewhere around the slots always lights up WHENEVER a card is plugged in without the EZ Plug put in.
