A8N32-SLI Deluxe - Unknown Device
TechLarry
RIP [H] Brother - June 1, 2022
Ok, I'm stumped.
What the hell is ATK0110ACPI and why is it trying to drive me insane.
It's in the device manager as a "Unknown Device". I've tried everythign to satisfy this beaotch and it won't go away.
Yes, I've tried inserting the ASUS DVD. All it says is the installation failed because the software is not for this system.
I have no idea what it's trying to install.
-Larry
i've seen this before~
do you have a dvi flat panel? i think the 'acpi' means it can go to sleep, the rest might be a model number. good luck
After reformatting, I got the same thing (I think). Lemme check.
EDIT: yes, exact same thing. No clue what it is either, because my comp is functioning fine without it.
Is your nvidia ethernet port messed up too? Hopefully it just has to do with how fked that port has had me.
Just get the Asus Driver CD put it in and let it browse for driver. Thats how i got mine installed ;)
Well, I did that and it initially said that it didn't find anything. But after doing another run and selecting that option to let Windows scan online, it gave it a 'Microsoft Windows Hardware Compatibility' driver. Gonna go reboot later on and we'll see wth it did.
I had the same thing happen to me when I got my ASUS board up and running. All you have to do is put the ASUS driver CD in your comp and let it autorun (no need to browse anything). That'll fix the missing device problem for you. :)
Tried that, no joy...
-Larry
Ok, got it figured out.
Whatever this device is, it's controlled by the ASUS AI Booster utility. In fact, with this device not working AI Booster will give an error (dumb error, a 1" X 1" window that says error in it - thanks Asus :)) at startup.
Now, because I had fiddled with it so much, Windows had done it's little trick of assigning a totally wrong INF file to the device, and there was no way to automatically install the correct driver. I had to do an "Update Driver", and use the method to force-feed the driver instead of using the auto-search stuff. I pointed it to the ACPI folder in the Ai Booster folder, and it brought up the window asking to select the device. Finally :) Told it which one to use and it installed, and this nightmare of an issue finally went away.
It took me 2 hours to build this entire machine, including installing Windows, and 2.5 hours to figure this crap out.
BTW... Acronis TrueImage 9, which is MP aware, really flies on this thing :)
-Larry
-Larry
Makes sense. this is the only time I didn't install AIBooster.
wth are you talking about in your 2nd line? lol
I'm afraid I don't understand the question.
-Larry
I got that type of error on my DFI Expert board, just a little box that reads "error". No program name or enything like that just "error". IIRC for me it was a conflict between another program and Smart Guardian which was solved by not having SG auto start.
