TwistedMetalGear
- Jun 19, 2005
Hello, I just got my system up and running and there are two things in the device manager that don't have drivers installed...
The ethernet thing is not a problem, I found the drivers for it on the Asus CD but I'm not installing them because apparently it is just another ethernet adapter which I don't need. No harm leaving it uninstalled, right?
Anyway, my main concern is the RAID controller as seen in the pic below. Do I need to install drivers for this? I already installed the nvidia nforce4 X16 chipset drivers(newest version from nvidia.com)... The only thing left to install on the asus CD is the Silicon Image RAID driver... I clicked on it, and apparently it is a RAID5 driver, which makes no sense since I am running RAID0 so I didn't install it. Before I set up windows, I installed the nvidia RAID/SATA drivers from a floppy which worked with no problem.
Also, on my taskbar where all the icons are at the bottom right, there is a "Safely Remove Hardware" icon which lists both of my hard drives. Does this have something to do with that RAID controller thing mentioned above?
Please help if you can, I hate having exclamation points in device manager.
