A8N32-SLI bad sli preformance !
Super KW
Now i add anew card and formatted my hard drive install all updated chipset drivers , video drivers , sound card driver every thing are up todate include bios !
sli enabled in the nvidia control panel , sli bridge are connected ,asus ez plug connected, power supply are 650 w with dual 12v 19amp each , case has 7 fans
MY PROBLEM WITH BF2 FPS ARE LOW NOT LIKE SINGLE CARD EVERY THING ARE MAXED OUT AND MY FPS 50 to 60 BUT WITH STUPID SLI FPS ARE 17 TO 27 AND STUTTER
WHAT WRONG NOW !
PLEASE HELP
Ha, I got this card cause of the 16X/16X and my 3dmark scores don't really change with it compared to 8X/8X. Also, My PC Probe II keeps having alarms go off for the MB temps. It keeps going to 48c which is hot for a chipset. I really don't like this mobo (that's with my room super cold!).
I am just going to end up selling it local and just get an Ultra D. This is my first asus board and not really excited about it. *shrug*
i have the same temp 48 to 50 i think its normal
but realy i dont know what to do now is the powersuply issue or motherboard ?
make sure the SB<->NB link is 1000mhz/5x multi
somtimes it sets it at 2x unless ur OC then run it at the CPU-NB link speed
most def not normal. My mobo temps have never been over 35 no matter what i'm doing. I've never seen anyone with a board that hot inside a CM Stacker, maybe you should get a new csase?
Well, my case has a lot of fans and always ran my other processor and mobo's at 29-31c... this is the first mobo\cpu combo i've had that has high temps even when it's not OC'ed. I think I want to get rid of it so I can just get a DFI...
its not case issue iam sure because i have 7 fans on it ! how many fans should be in case ?
16x per card is only future proof, there is litle to gain from today's cards and games.
40-50 C is normal if you have sli cards blowing air on top of the southbridge, just add a fan or two to keep air moving in that area.
Two 78/512 cards blow their air out the rear, so no buildup on MB.
:mad: when I opened my window when it was like 20 degrees outside and closed my door... (to keep the cold from going in the rest of the house) my cpu temps dropped to 30c's... but STILL!! Ambient temp has always been like 65F when my past setups all ran under 33c. Grrr... someone let me borrow their steam roller and run over my rig.
Those boards have problems with temperature reporting, your temps aren't really that hot, I can almost guarantee it. Feel the southbridge, it should be warm, but not too hot.
Oh, I guess you're right. I didn't think about the two videocards heats lingering around the southbridge. I am sure I can get one of those fans still and slap it on top.
