A8N32-SLI and Floppy
MoFoEd
Just finished building the PC with this new mobo but now I see my floppy can't read anything. The flippy shows up in XP but doesn't read any dick, keeps asking to insert a disk. I have tried many dicks, swithcing floppy cables, hell even swappy Floppy drives but nothing! I wanted to update the BIOS on this but now can't, and I still use the floppy for other reasons.
Any help will be greatly appreciated.
MoFoEd said:
The flippy shows up in XP but doesn't read any dick..... I have tried many dicks.....
o.0
:eek: :eek:
I would suggest you try putting a floppy DISK in....instead of a floppy....ahem :p
Maybe you aren't using the right sized dick.........perhaps a black dick might work better..... XP (ah the fickle woman that she can be) just isn't satisfied with small dicks, even if the flippy shows.
Toonage said:
Maybe your aren't using the right sized dick.........perhaps a black dick might work better. XP (ah the fickle woman that she can be) just isn't satisfied with small dicks even if the flippy shows.
bwahahahahahaha :D
Hhmmm... have you tried plugging the floppy cable upside down? Like you know how the connecter is a long rectangle with a notch on one side? Make sure that the notched side is facing down. For some reason, I was able to install my floppy disk regardless of which way it was facing, but there's only way for it to work.
