a8n32 help please!
barcop
I updated the BIOS last night to 1103, and now my system won't POST with any video signal.
I've taken everything out, even the video card, reseated everything, and even just left the CPU and video card in, and still nothing.
I've cleared the clock settings, that didn't work either.
I tried putting the video card in the 2nd PCI-E slot, still nothing.
Any ideas?
If you can get BIOS 1009 on a floppy named 'A8N32SLI.ROM', then keep hitting 'Alt+F2' after powering up. This will blind-flash ('EZ-Flash') your BIOS back HOPEFULLY. Many are having trouble with 1103 (mostly RAM trouble).
You can try clearing the CMOS and then booting again. That should use "safe" bios settings. I had to do this when my flash to 1103 went sour.
Took a long time, but I found out that once you clear the CMOS, you need to boot with 1 stick of ram ONLY.
Up and running now, thanks for your help!
