A8N32 HELP PLEASE>INSTALL PROBLEM
I just bought a asus a8n32 with a Amd 4200+ x2 and a Zalman 7000 fan....do i need the backplate to install it? Theres some weird steel plate on the back of my motherboard and i cant install the zalman black plastic backplate...do i just install with the nipple screws and mount the fan that way??? please help...anyone who has a zalman 9000 series could help too!!
Honestly if you have never installed a cooler that need the MB backplate removed ............... i would stay clear of that. There are plenty of coolers out there that do a very good job cooling that dont require you to man handle your MB. Good luck.
The back plate on this mobo is just stuck on, it simply needs teasing off gently with a blunt lever of some kind.
No drama unless you're a real dyspraxic :)
