I have OC'd my 3200+ to 2.7 and the ram is running at 180mhz and I can't find anywhere in the bios where the cpu-ram multiplier. I can tell that it's 3:2. Need help because it's getting annoying and think it's bottle necking my CPU, or is that untrue?
go into bios and go to ram settings and set the speed to 333 or 200 or 266.you have to dial in the frequency to use.at 200 you would be 1 to 1 at 333 youd be 5 to 6 or something like that.
that is a good mobo you have there,i setup several systems with that board and i was happy with all of them.they o/clocked well and i never had a problem with any of them.im currently using the a8n-e and its in my opinion a perfect board.it does everything well,same as the a8n sli board.im not a gamer so the non sli version does me just fine.
I know it's a good mboo because OC'ing was well done but the max voltage for the CPU was 1.55V in the mobo but appeared as 1.57-1.6V in real life. Odd?
Thanks again.
EDIT: It works and it's OC'd to 220mhz at the clocks of 3-4-4-6. On generic ram
