This information is for those who might be looking for answers to storage issues on the Asus A8N-SLI. I searched everywhere for this info and could not find it. If its old news to you, discard it, otherwise I hope you find it helpful.
Two issues
Installing Maxtor SATA II drives on A8N-SLI
Using Silicon Image Controller (SATA only) for SINGLE drives (not raid)
I have the Premium version of the A8N and have been struggling with trying to upgrade my storage options after a HD crash. I purchased a new Maxtor DiamondMax 10 6V320F0 320Gb drive (SATA II) and tried to install it in the system. I could not get it working no matter what I did. The BIOS recognized it, but when trying to install Windows, it would crash after copying the setup files to the drive. I could not even set it up as a secondary drive the system would just hang on startup. There are a number of posts around talking about issues with Maxtor drives and the A8N.
The problem is with the Maxtor NOT the board or Nforce4 chipset. The fix Maxtor have a new firmware that must be installed. You have to call them and get (for this drive at least not available online). My drive came with the firmware VA111610 it must be upgraded to VA111630. They will send you the flashing utility and the firmware. Once the new firmware was installed all issues went away.
Second, I have been trying to set up individual drives using the Silicon Image RAID controller on the A8N board. Finally I worked out how. Enable the Silicon Image controller in the BIOS. On new startup press Ctrl+S to open the RAID setup. Add ONE drive at a time. Set up the single SATA drive as a JBOD single volume and choose the drive. The utility will indicate the capacity of the drive select full capacity. Boot to Windows. Install drivers for Silicon Image RAID controller. REBOOT. Then after reboot install Silicon Image IDE driver (From ASUS disk Drivers\Si3114\Disk\Si3114r5r.*) your drive will then appear in explorer. Then simply reboot, repeat the process installing the second drive and set it up as a second JBOD single drive, boot into Windows and your drive pops up in explorer.
Two issues
