freddiepm61
- Oct 19, 2004
As can be seen from this picture, nv 5 could most certainly fit, due to asus changing setup for better air flow.
however if you look at the bottom right down by the 8 SATA connectors (the four red ports and the four black ports), if two nv5 were installed, would the fan completely obstruct these SATA ports? bear in mind i do only need 3 available....
moreover the black ports go via the nforce 4 chipset. the red ones are an add in chip from asus. therefore would performance be faster in the black nforce 4 ones?
thanks
f
thanks
f
