Chrissicom
- Jul 7, 2005
Hi, I have an A8N-SLI Premium Revision 1.02 with Bios Rev. 1302 and 4 512 MB Corsair modules (CMX512 3200LL CL2 Timings: 2-3-2-6).
When I use two of the modules (no matter which 2 of the 4 I choose) and insert them into either the black or the blue slots on the board they are detected properly as 400 Mhz 1 GB Dual Channel memory.
When I use all 4 modules they are detected as 333 Mhz 2 GB Dual Channel memory with extremely slow timings. Setting the speed manually to the correct speed of the chip (400 Mhz) will kill the system so I have to clear CMOS by removing the battery and using the CMOS jumper.
I wrote to Asus support about this with a very detailed problem description and I had to write down all of my hardware and stuff and the "stupid" reply was I should overclock my CPU a little or try setting the speed of the RAM manually. Well, I will not overclock my CPU because that kills my warranty (my X2 3800+ is only 7 months old) and I already told them that setting the speed manually doesn't work but they seem to have ignored that.
Does anyone here have a similar working setup? Maybe another Bios version will do the trick?
