I've read user stories with the a8n-sli all over the net, some saying they can't get more than 230mhz htt (which is my current situation) and some saying they get completely rediculous numbers of 280+ so I was wondering what htt's [H] people have been getting with their a8n-sli's. It's really wierd cause I can crank the htt all the way up to 300 and the system posts's fine with no corruption but after it detects the ide drives it locks up, however, if I go into the bios it goes right through the detecting ide devices and goes the raid controller then enters the bios where it will sit happily for hours at 100% usage never going over 105F. This would seem to me to indicate that the processor is able to handel the 900mhz oc. I know the a8n loads defaults when post fails without telling you but when it does that it doesn't hang after detecting the ide drives and the cpu configuration says 2700mhz, also why would it be able to move on to the nvraid bios only when I tell it to enter setup? I thought the issue might be related to not being able to lock the pci multiplier but I just flashed 1007 last night and it had the pci lock setting which I set to 33.33mhz. So now the only conclusion I can draw is over 230mhz htt is completely unstable on this board though it seems odd that so many people would have the *exact* same max stable htt with a round number like 230mhz. So, what do yall think?
