A8N-SLI Not Booting
mchammer
Long story short: was looking in my computer to see where I could fit my Radiator for my new watercooling setup (which has not been installed yet), took off a fan or two, and then put the computer back together. NOT BOOTING. I have built 10+ computers for myself, family, and friends so I'm not a total n00b.
After several tries I put the whole thing back together from the start (except for the CPU). It would not boot several times and then out of nowhere it boots again, but after getting on the net I get a BSOD. So I reboot again to get a "bootdisk failure". SO I try several more times and then get it booted again, but was only getting a video out from the analog output of my vid card.
As it stands I get no video signal either analog or digital, but my fans are spinning.I suspect it is either the MOBO or the Hard Drive, but have no way of testing my system with other components. I'm thinking it's the MOBO because I can hear the Raptor making noises when I first power on. I built the system from scratch a couple of weks ago so I should be able to return whatever it is that is giving me trouble. Also, board was OC'ed for a while but when I got it rebooted again I set everything to stock.I appreciate any help and suggestions. Thanks.
Specs are as follows:
ASUS A8N-SLI Deluxe (BIOS 1003.4)
AMD 3200+ Win. (Retail HSF)
G.Skill 4400LE
74GB Raptor
OCZ Powerstream 600W
1 x eVGA 6600GT
G.Skill 4400LE
74GB Raptor
1 x eVGA 6600GT
If it would POST at all, I'd suggest resetting the CMOS, then reflashing the BIOS, either a rollback to 1002, or grabbing 1003.007, it's on ASUS' site now.
I wouldn't see why you would if you were just popping it open to see where to fit in a radiator for a watercooling setup, but did you pull the motherboard, then remount? Maybe the motherboard is shorting out?
And did you remove either the 24 pin main motherboard power cable, or the four pin one next to the CPU? If you did, make sure each and every wire is seated properly. I once, on another build, had a wire come just slightly undone from a 20 pin connector of a PSU and act like the board was going to come up, but never actually boot. Gave me fits because when I'd pull the board to test it on a table, it would power up with another power supply. Finally noticed that on the power supply in my case that one wire was just very slightly off, and would wiggle a bit when I moved it, so I pressed it back into the 20 pin connector. Problem solved. Was an almost new PSU also, so and good brand, and Enermax.
The answer you won't like is that maybe you shorted out your motherboard if you weren't properly grounded when you looked in? Please don't take this as a response to a n00b, but did you unplug the PC and maybe even press the power button once with it unplugged to make sure all the power was out of the capacitors?
Thanks for the reply Arvig. I tested and the board is not shorting inside the case and the power connections are fine. I found that when I reset the CMOS the board would boot just fine, but boot only once. So I rolled back to BIOS 1002 and now it will boot into the BIOS just fine everytime, but still no DVI output only analog, and the board will not recognize my Raptor. The board did recognize my 160gb IDE drive but I need my raptor because my IDE drive is my backup and is not pertitioned and I will lose all of my saved data. The BIOS shows the CPU as running at 4000MHZ!!!! So is it a BIOS issue or is the board hosed? Thanks.
Also, will most retailers cross ship on an RMA if you pay for the new board and will refund when they recieve the older board?
The majority, if any, will not cross ship on an RMA. Once they receive the damaged or defective item, then they will ship out your replacement.
edit: A Mom and Pop shop MAY cross ship, but I still doubt it.
Praxi said:
asus will cross ship if you deposit the purchase price.
Sorry, but can you point me to where I can do this. Asus's site is just a little user unfriendly. :rolleyes: Thanks for all the help. :D
I just called their RMA department, ask them about cross shipping.
The number I called is 510-739-3777. You should have to have a case # first from the techsupport guys, that says you get an RMA. If you get some thing about leaving a message, just forget it and try again. I left a message for 2 days with no response, called back and was on the phone with someone in 5 minutes.
Yours probably is a bad board. There is a known issue with the 1003.00x and the so called 1003 Final BIOSes and dropping Maxtor NCQ drives (and from what I've seen sometimes Seagate NCQ's), but not Raptors, I've seen plenty of people with Raptors as single drives or RAID 0 do fine on both 1002 and 1003.00x. Believe it or not, reporting the wrong clock speed on the CPU is kind of normal, only seen it done once on my board, but when I initially POSTED I think I saw something absurd like 6800 mhz. (Hey, it was a nice overclock if that was a real report). But dropping a SATA drive that isn't NCQ isn't normal, especially under BIOS 1002...so yeah, you probably have a bad board.
I've had a similar thing happen. I took my a8n-sli to a lan, only to boot and find out that both my onboard nics had disapeared, my 1394 port could not start, and everytime I would reboot windows would run a chkdsk on drive c, and half my files would go away.
I reinstalled, and when I brought my system back home the same thing happened. The strange thing was that prior to moving the PC it operated flawlessly.
Long story short: I found out that with using any bios over 1002, the motherboard becomes unstable when it is disconnected from power. I can install and play games for weeks without any problems, but disconnect the power and it's reinstall time. I eventually rolled back to 1002 and havn't had any problems since.
I suspect that what was happening was that after power loss, the motherboard was reading eroneous info from the bios, and setting the pci bus at a frequency higher than 33mhz. All of the symptoms I saw will also happen if you overclock your pci bus.
Well, got the board up and running, I guess you are right Kellog. I noticed that I had not replaced the CMOS battery last time I clearted it so maybe that is why I was having issues. But 1002 will be my BIOS until I know that there is a working final bios released. Lesson learned: DO NOT USE 1003 until final. Or at least I'm not going to. Thanks again for all who gave feedback.
Ya... mine won't even POST for some reason.
I tried plugging in headphones into the LIME port to check for any vocal post errors but I get nothing. System boots up, fans are spinning, hard drives are spinning, etc, but I can't seem to get any type of POST from the Mobo.... I'm kinda stuck so if you guys wanna walk me through everything so I can look through my board i'd be much obliged. My memory is seated properly, CPU installed correctly, so I don't see how I can't even get a POST with errors or anything :\
Specs:
3500+ winnie
512x2 OCZ pc3200 rev. 2's
antec 480w truepower
bfg 6800gt
36gb raptor
I've put out the 6800gt just to see if I can get any bootup process, but nope. Nothing.
EDIT: Stupid me wasn't used to connecting the +12V 4 pin.. that let me boot up. But now I'm getting the whole system failed VGA test.. :( ugh
Specs:
3500+ winnie
bfg 6800gt
36gb raptor
Rharshbe, I flashed the BIOS back to version 1002 from a floppy. After I did that I reset the CMOS by taking off the the onboard battery and moving the jumper over for a couple of seconds. Then replace the battery and boot. I went through the BIOS and changed a couple of things to suit my taste and that was it. The instructions for reseting the BIOS are on '2-17' of the MOBO manual. Are you using 1002?
Also, I have an LCD monitor with a DVI input and was not getting a signal. I actually booted into windows with the analog out and had to change the settings in the display properties, so you may need to do that if it applies. If you need anymore help let me know.
Ya, got mine all running now. Scared me for a bit as I had put the zalman hsf on my 6800gt -- but alas XP is now installed and all is well. I can rest peacefully now. Thank god too, I was about to freak.
