A8N-SLI (non-deluxe) oc problems...
godzboyz
When ever I start up nTune software there would be a warning messege that says: WARNING: YOUR PCI CLOCK IS CURRENTLY SET TO TRACK HT BUS. IF YOU ADJUST THE CLOCK FOR HT BUS, THE PCI CLOCK WILL CHANGE AS WELL. PLEASE CONSULT YOUR MOTHERBOARD MANUAL TO DETERMINE HOW TO DISABLE THIS BEHAVIOR BEFORE PROCEEDING.
My memory timing is 3-4-4-8
I looked everywhere in the manual and there is nothing that says anything about disabling the PCI - HT bus locking system now I can't do any overclocking at all because of this and if I do my computer restarts instantly any help would be appreciated thanks for reading.
I have an A8N-SLI (non-deluxe), AMD64-3200, 2x PCI 6800's and 512mb or HyperX ram and I am using WIN XP...
I'm not sure of the non-deluxe bioses, but for the deluxe model, I believe it's 1004+, there's a setting for PCI clock synchronization. You can set it to [auto], [cpu], or [33.33mhz]. If you set it to 33.33mhz it should lock it.
