A8N-SLI (non-deluxe) oc problems...
godzboyz
When ever I start up nTune software there would be a warning messege that says: WARNING: YOUR PCI CLOCK IS CURRENTLY SET TO TRACK HT BUS. IF YOU ADJUST THE CLOCK FOR HT BUS, THE PCI CLOCK WILL CHANGE AS WELL. PLEASE CONSULT YOUR MOTHERBOARD MANUAL TO DETERMINE HOW TO DISABLE THIS BEHAVIOR BEFORE PROCEEDING.
My memory timing is 3-4-4-8 and it is a kingston HyperX PC4000
I looked everywhere in the manual and there is nothing that says anything about disabling the PCI-HT bus locking system now I can't do any overclocking at all because of this and if I do my computer restarts instantly any help would be appreciated thanks for reading.
I have an A8N-SLI (non-deluxe), AMD64-3200, 2x PCI 6800's and 512mb or HyperX ram and I am using WIN XP PRO..
I can't even get my system pass 2.1 ghz on a winchester.... and I don't think it's even stable at 2.1 because it crashed twice at that speed while I was doing some virus scan....
uninstall the software overclocking ASAP!
get your ass in the BIOS
Some tips ( i have this baord, non delux)
-Timings really depend on your memory, as the DDR volts. Assumming you have some ok stuff... Set them it to 2.5-3-3-7 2t @ 2.8v (running 1t is strongly advised, but its hard to do with dual 512 sticks...so run 2t for now.
-The set you memory to 166, this will factor out the memory.
-run a 4x LDT mine wont overclcok 5Mhz HTT with a 5x ltd
-disabel cool and quite
-mine dosnt mind 1t when overclcoking, almost all of the delux baords freak out when running 1t. But it could be my memory also that liek it (TCCD)
The first thing i would go for would be 210HTT 4x LTD, memory on a divider (166Mhz) 1.5v core 2.8v DDR.
then i would go for 220x10 4x LTD 1.5v or so. After that i would try to get my memoy up to speed, and try 220Mhz 1:1
crap..ill finish this post in a min, got to swap to my laptop before i wake up my dauh-ter...
Last night or should I say today since it's 1:30 in the night.... I was able to OC from 2.0 ghz to 2.58 ghz stable thanks to you ur the best.
godzboyz said:
my super pi 1m scored 45 second before OC now it scores 36 secs :)
ouch, thats high dude...i think, at 2.7 i score 32.332 at 2.6 im in the 33s...
hmm thinking about it..that about right for 2.5Ghz...expecially since you timings arnt 2-2-2-5...
NM Good job.
