A8N-SLI Deluxe RAID Issues?
Mr.Dru
Im just trying to run RAID 0 array on this board its been a pain in the ass. i used the make disk tool on the supplied CD. when prompted to install third party drivers i pressed F6. the two sets of drivers that popped up...the first with the RAID label straight didnt work and the other labeld NFORCE drivers gave me a BSD. evrything in the bios is right and i used the nvidia tool to set up the RAID 0 so as far as i know im doing everything right. any suggestions?
Iy you give me your email I will send you the drivers that worked for me!
If it's not dropping your hard drives, and you're on BIOS 1002 on your board, I wonder if it's a power supply issue? Before I switched to a 24 pin PSU, I had a hard time installing Windows. When I finally did, it would lock up a lot of the time right after the Windows splash screen. Switching to a 24 pin PSU solved both problems, even though I didn't change voltage or amperage...in fact, I went from a 20 pin PC Power & Cooling 510 Deluxe to a 24 pin PC Power & Cooling 510 SLI, both are the same PSU's if you ignore the different cables, same wattage and amps.
What PSU are you using, and are you using two video cards that take seperate power plugs? With a 20 pin PSU, if I made sure each video card had two molex plugs for the molex to six pin plug converter cable, I went from having this problem a lot to just having it once in a while. As I said above, going to a 24 pin of the same make and model of PSU cured it completly.
Of course, I can't use anything but BIOS 1002 due to the 1003.00x BIOSes possibly not liking my NCQ SATA hard drives, but that's literally another thread (and I started one about that. ;) )
Me
thanks for the advice. i think im going to toy around with a non raid setup and see how far i get
