A8N-SLI Deluxe Problems
Inglix_the_Mad
System:
AMD Athlon 64 FX-55
A8N-SLI Deluxe (1006 BIOS)
2Gigs of PC3500 Level 2 Mushkin (1 Gig currently installed, I'll hit that later)
1-74Gig Raptor (on Nvidia SATA)
2-GeForce 6800GT PCI-E (BFG)
Aopen 16X DVD-ROM
Aopen 16X DVD-R/RW
Enermax Noisetaker 600w
Coolermaster Praetorian Case
Now to the problems:
1) System never sees more than 1.5GB of RAM so I have 1 installed for stability on the 939 platform, does this with Kingston HyperX too. Even does this on my board...anyone else have problems w/ more than 1GB?
2) System does not install Windows, it did get a PFN_LIST_CORRUPT stop error which I apparently fixed by changing it from APM - S1&S3 to just S1, now it gets an IRQ_NOT_LESS_THAN_EQUAL even after I tried changing RAM, turning off the LAN controllers, changing HDD, changing Motherboard. Everything seems to work in my rig, could it be the NVRAID with the single raptor?
I don't think it's a ram size issue as much as its an issue with populating all four memory sockets. With my A8N-SLi Deluxe I found that it wouldn't detect the memory timings of my memory modules correctly, I had to manually set them. You also will have problems running at 1T with all four chips installed. Set it for 2T if you haven't already.
try flashing up to the newer 1007.002 beta bios. i've been running rock solid on it for going on 3 weeks. same as Fragalot, try setting 2t instead of 1t and manually set your memory. reset your bios to factor defaults and change only what you have to little by little. i'm not sure how far you got into the xp install, i'd guess when it starts loading windows in the text based portion before you can try a drive. if so, only hookup a cd-rom and leave your raptor unhooked. if you get past it, you've found a problem.
