Slartibartfast said:Before you buy anything try squirting some WD-40 in there, sometimes that helps.
WD-40 is not a lubricant.Slartibartfast said:Before you buy anything try squirting some WD-40 in there, sometimes that helps.
RailGunRiz said:++ Don't bother with asus either for replacements, they take their time (like 3 weeks on avg. if not later).
Mayhs said:similar problem with my one....the chipset fan goes to arund 2000-3000 and starts making weird noises...its normally at around 8000rpm is it dieing?
I(illa Bee said:the Fan on my ASUS SLI was too damm loud so i unpluged it.. Comp has worked jsut fine since (over 4 mounths) and i even overclcok pretty good too....
c1001 said:No chipset cooling at all? That is impressive and hard to believe. I put in a heavy Swiftech MCX-159-Cu in my Asus SLI and unplugged the fan to see how well it would work passive. It got almost too hot to the touch within a few minutes. All that heat in my case got me worried, so I plugged the fan back in. I know that other people use the passive Zalman cooler and it works fine for them. Maybe the less dense aluminum dissipates the heat better. I just can't imagine the board not overheating without some kind of cooler on the chipset.
Not even. I'm not losing my motherboard for a few weeks just to get another failure-prone heatsink-fan installed.[BB] Rick James said:I think the obvious answer is RMA????
VulturEMaN said:I bought a SWIFTECH MCX-159-R back before they were discontinued, and I can say that my temps have never gone above 27C. It's a nice universal chipset cooler...If you look around, you'll see the excellent reviews...but it is truly hard to find one nowadays... pm me if you need help installing it
