A8N-SLI boot problem
skindogg
I've been searching, and don't see any mention of this. I just got an X2 4400 and an A8N-SLI with an Enermax 535W SLI. After hooking everything up, LED lights up on the board but won't boot. Now on a hunch, I hooked up my older Antec Truepower 480W with the 20pin + 4pin and it boots fine. The enermax is a 24pin connector. I'm guessing that takes care of the extra 12v for the cpu, that and the enermax doesn't have the extra 4pin 12v. So bad enermax psu?
i have the same setup and it works fine. Do you have the extra 4 pin connector installed as well. Little more info would be good. I find that the ASUS board is very good with booting up even when things go wrong. and they have verbal warnings about what is going on if you can get to the post screen. post a little more info and I would be happy to try and help you.
The enermax 535W SLI doesn't have the extra 4pin 12v connector, although the 24pin connector it does have has a detachable 4pin making the connector a 20pin, but I'd have to cut off the sheath to stretch it up there. It already has a 24pin connector, is there a reason why i'd have to detach it?
Other info:
X2 4400+
A8N-SLI
2x1024 Corsair TwinX 3200C2
2x74Gb Raptor
MSI Lite 7800GTX
