A8N-Sli 1003 BIOS Final
GooN3r
ftp://ftp.asus.com.tw/pub/ASUS/mb/socket939/A8N-SLI Deluxe/1003.zip
No word yet on how it works but here is a summary of so called improvements:
BIOS version: 1003 Date:01/20/2005
Checksum: C700H
1. Modify A8N-SLI DELUXE BIOS version to 1003.
BIOS version: 1003-010 Date:01/19/2005
Checksum: EE00H
1. Modify HT safe value from 5X to 4X to fix somtimes K8 sempron CPU fails to boot
2. Modify CPU Vcore for 1.40V (Low Power CPU) for MR
3. Hide 'CPU Voltage' Item options from 1.55V~1.65V when using 1.40V CPU, because the low power CPU doesn't support upper 1.55V
4. Modify Linear Overclock formula to fit H/W request
5. Add a SETUP Item to control the CPU fan fail message threshold RPM
BIOS version: 1003-009 Date:01/17/2005
Checksum: 5200H
1. Re-translation item strings, value and help to French.
2. Don't porting GPO5 to fit H/W request
BIOS version: 1003-008 Date:01/13/2005
Checksum: CD00H
1. Fixed asus update 64bit OS fail
2. Change the SLI mode setting from 'SLI' to 'auto' when user switch to Dual card mode by SLI windows utility
3. Fixed CPU voltage will pull high in the begining of POST and then pull down after memory sizing
4. Do one more time PCI_reset to fix fail to boot from bootblock after support DualGPU card
BIOS version: 1003-007 Date:01/11/2005
Checksum: 5E00H
1. DMI information : Fixed AMD Athlon64 CPU's Processor Family will be wrong shown as 'Opteron'
2. Add DMI type08 information : 'CPU Fan','Power Fan','Chassis Fan * 2','Chipset Fan'
3. Fixed when CPU multiplier select 4X or 4.5X and HT set to 5X , system will hang on 29h , it is because the HT speed cannot be faster than CPU speed (AMD Spec)
4. Fixed AMD Sempron can not boot up because wrong HT setting.
5. Fixed DDR CL value will be wrong after resuming from S3 (only MR PCB)
6. Support nVidia DualGPU PCIE VGA card.
7. Rewrite EZ-plug checking code to support both Normal/QuickSwitch PCB
BIOS version: 1003-006 Date:01/06/2005
Checksum: 3D00H
1. Correct Hyper Transport item string for multi-language..
2. Support Setting SLI/Normal mode by windows utility
3. Change CopyRight year from 2004 to 2005
4. Modify AMD K8 939 3800+ PST table to fix failing to enter OS when enable cool'n'Quiet , the solution is change the lowest VID from 1.1V to 1.2V
BIOS version: 1003-005 Date:12/30/2004
1.Fixed PCI Clock locked on 33MHz (PLL to CPU) fails to work
BIOS version: 1003-004 Date:12/22/2004
1.Change VID Max Value from Vcore_Default+100mv to 1.65V
BIOS version: 1003-003 Date:12/15/2004
1.support PEG for ATI X850 PCIE card
2.Modify DDR speed :in Class A, when 4 DIMMs pluged , DDR400 will down to DDR333
3.Set DDR timing reg TRP,TRCD min value to 3
BIOS version: 1003-002 Date:12/09/2004
Checksum: 3C00H
1.Fixed when overclock over 220MHz , HT doesn't down to 3X
2.Change MR table D , overclock over 240MHz , DDR200==>DDR266
BIOS version: 1003-001 Date:12/03/2004
1. Modify Cool 'n' Quiet string and default value
When i flashed to this bios, it made my Hyperbus go down no matter what i did. I had to flash back to 1003.5 in order to keep my overclock of 250 fsb stable with the right multiplier on the Hyperbus.
1003 final makes the Hyperbus go to 4 X instead of 5X. It's one of the changes made in the bios.
How do you check the hypertransport multiplier? I'm running the 1003 final bios. I set the multiplier to 4x, but SiSandra shows frequecies implying that it's really set at 5x. What's a good tool to check this with?
"Final" BIOS or not, this one, just like the beta BIOSes dropped my Maxtor Diamond Max 10 NCQ hard drives. So, "Final" or not...they didn't fix that problem, the same problem the beta 1003's had with NCQ hard drives.
Oh well...
i hate to say it, but maybe you should just get a rapter and call it a day huh? Im sorry man, but its time to enjoy what you bought. Maybe it wasnt the best idea to get NCQ drives on such new hardware. They should work, i understand your view but, i know i wouldve like one too, but its new and the board is new so i figured go with what works and maybe down the road go to NCQ. My rapter is pretty fast anyways.
They sell the product saying it works, if the controller doesn't support NCQ, the drives should still be seen, just without NCQ operating. If you buy something, it should work the way it's sold as. I just dropped a grand on 4 of those maxtor drives and I expect them to work on any SATA controller, with or without NCQ.
Tell you what, buy my hard drives and I'll follow your advice. :p
I'd hate to say it, but you really did a lame post here.
If I buy a Raptor or two what do you suggest I do with my current drives, use them as paperweights?
(YES, I can RMA them, or try them on the Silicon Image ports... )
Anyway, already made up my mind. The DFI board won't be out for a week or two, maybe three weeks now. So...ASUS MAY start with new BIOSes that address this NCQ issue. If they do, and it's fixed, good. If not...well...I guess I'll get the DFI and either RMA this board or sell it on eBay. Since I'll be getting some of my money back, at least that's cheaper then just buying hard drives and throwing away my old ones. ;) Worst case, the DFI doesn't like NCQ, and I have to move to the Silicon Image ports...but I'm at that impass if I use a BIOS past 1002 on this board anyway.
EDIT: Bah, maybe I was a bit pissed off when I posted this. Still think your suggestion is kind of lame...but I know you meant well and didn't mean to flame. :)
Err...that and I'm now starting to wonder if it is just the Maxtor drives and I'd be screwed even if I did switch to DFI or MSI unless I use the Silicon Image ports. I might debate that this weekend, and actually take your advice. (So...maybe I'll even recant on calling your post lame if I do this..naw, I know me, I'll still call it lame even if I take your advice. ;) )
Hey, there's always eBay, if Newegg wants a restocking fee on my current hard drives.
I have a 400GB Seagate that supports NCQ and it runs of the nVidia and SI ports.
Weird...not saying this is bad for your of course, but I've seen people complain about Seagate NCQ's also.
Still...I'm starting to think my semi-flame above of Tripp17 was uncalled for, and ordering two new drives is the way to go.
Hmmm...don't think I'll risk NCQ regardless, though.
What's the problem with the Maxtors? I was thinking of an SLI setup with the ASUS, coupled with the 200 or 250gb version the of the sata16mb cahce DM10.
Thanks.
Thanks.
The Maxtor Diamond Max 10 drives with NCQ, and possibly the Seagates with NCQ also can't be seen with the NVidia SATA ports if one uses a BIOS newer then 1002. The boards are probably still shipping with 1002, but the new final BIOS, 1003 just came out, and it still won't see NCQ drives on the NVidia SATA ports.
This might not sound so bad, excpet that 1002 is a poor BIOS for overclocking. Without using a third party utility like Clockgen, I can't get my FSB past 210 using BIOS 1002 without it posting an overclock error, yet the newer BIOSes, and the same CPU on a different board has no problem with it. Without going into details, with 1002 one also has to jump through some minor hoops to make sure the PCI bus is locked, 1003 final and the 1003.00x betas have settings for the PCI bus to lock it down.
That's it in a nutshell. At least with this board...MAYBE other NForce 4 boards also, avoid at least the Maxtor NCQ drives if not all NCQ.
As an aside, saw a post on www.pcper.com in their Chaintech section where a guy had problems with a seagate NCQ drive on his Chaintech NForce 4 Ultra board...but they looked a bit different, so don't know if it's related.
Sorry to double post, but as of the date and time stamp of this post, ASUS has pulled 1003 from their site. Haven't looked via going to the ftp sites, just via the Global URL then going in to download, did so to see if they already posted a 1004 Beta BIOS. So...maybe they figured out they didn't fix anything with regards to NCQ and are redoing the Final? Would be nice if this is the case.
I've been checking reguarly (several times per day) ever since the news came out that an official 1003 had been released and I have never seen and official version 1003 from the Global URL, only found it via FTP so I don't know if it was ever there to begin with.
Sorry about your troubles; I didn't know the maxtors would have compatibility problems. I don't plan on overclocking, and if I do, probably not for another two years when all this current equipment is buy worthless; maybe it'll be alright if I get the drive anyways.
Thanks for the heads up.
I lost sli and all manner of stability, intemitant loss of nvraid controller and ultimately a toasted OS. What a fucked up bios version. Talk about 12 hours of hell .I am finally back to 1002 and staying for awhile.
Thanx for the info. I was about to flash mine. (if it aint broken, dont fix it)
:confused: :p
I saw the 1003 final bios on their http page under release bios's. It is no longer there. Looks like they pulled it from the site to me.
The "old reliable" site to get things that aren't on their http, ftp.asuscom.de, only has 1003.006.
Personally I am sick of this. I've had this board in test for a month now, longer than any other board ever, and it still doesn't have a non-beta stable BIOS. If they don't have a perfectly working 1003 or whatever by the time the MSI comes out, I'm dumping the Asus.
KC
KC
Almost there with you, except I'll lean toward the DFI. I MAY kick around the idea of different hard drives and clone my NCQ drives to them, so that I can at least use 1003.006 or 1003.007...you can still pull down 1003.007 from ASUS without going to their ftp sites.
Either ftp.asus.com or ftp.asus.com.tw had a few other earlier betas hidden away, one of them had 1003.005 I think.
You might be interested to know that there's a *new* 1003 just posted at ftp.asus.com.tw!
Hmmm...not there now. Just looked. As of this post, they have a lot of the betas, up to 1003.005, but not 1003 final.
Now ftp.asus.com has 1003 Final up, but it's dated 1/21/05, so I assume it's still the 1003 that went up for a day, and then was yanked, the one someone said corrupted his OS install to the point of his having to reinstall Windows and roll back to 1002. They also have 1003.007, but one can download that from the ASUS URL already.
ftp.asuscom.de does have 1003.006, no other betas, and 1002 as of right now.
Again, if one goes to ASUS' URL to download, no mention of 1003 at this moment, but one can also get 1003.007 that way.
It's there... I just checked too. Zip dated 1/24, BIN file dated 1/20 (.007 beta BIN was dated 1/17).
KC
KC
Sure it was asus.com.tw? I must be blind, I'll look again, and edit my post if I find it.
EDIT: Still don't see it. Here's where I'm looking:
Only see up to 1003.005 there.
SECOND EDIT: Err...I won't ask why I couldn't see it before, but now I can. Well...wish me luck, here I go again. I'll post a new post here on if it works or not.
Addendum to Second edit: If it is a new 1003 Final, it still does the same thing to my NCQ drives, I almost assume it's the same 1003, since as of this second it's not on ASUS' URL download page, just the FTP site.
I installed the 1003 final a few days ago and it rocked my computer. First of all it set my hyperbus to 2x no matter what i did. Setting it to auto put it on 3x, but it still said 2x(i know becase the hyperbus was at 732x2). Even now that im back to the 1003.5(best for me so far with stability AND overclocking) the hyperbus still says 2x even though my total hyperbus is at 1968!! I wish i never went to the "final"......im back to where i was wich is 245 fsb x11 and my memory is at 1:1, but Sandra says my Hyperbus is set to 2 even though its at 4. I am not messing with it untill a official release is out.
Sandra is hosed. Don't believe it.
Well, it hasnt lied to me before....but like i said, even though its saying my hyperbus is at 2x.......its really at 4 because the hyperbus itself is at 1968. If it were really at 2x then my fsb would be at 984...lol. As long as its stable, i get great scores and i can overclock with no problems i dont care.
using 1003.5 BIOS. why the big deal about having a non-beta BIOS? all the NCQ guys I can understand your you problem and hope they fix it. But for those of us without NCQ drives, if the beta BIOS is treating your well (as it is me) who cares what they call it? I've been doing this crap since we were soldering in sidecars to PC-Juniors and as long as it works well who cares what they call it.
This board hasn't been out that long so don't get your panties in a knot yet, most people's problems are with overclocking... which isn't really what any board is mainly built for. I suspect that MSI is probably having similar issues and is just waiting till they fix them to release their board... price you pay to have things sooner.
Gee, this post was helpful. :rolleyes:
I'll remember to tell my NCQ hard drives that they shouldn't get their panties in a knot because they can't use any BIOS past 1002. :rolleyes:
Oh wait, that's a problem with it accepting hard drives that the NVIdia SATA ports SHOULD accept. Wait...is that a problem with overclocking? :rolleyes:
Have any other bits of "wisdom"? :p
I have the NCQ drives, so I was hoping that 1003 Final would be a cure-all to let me use them. I guess to answer for those who don't have NCQ drives, if I was in that boat I guess I would still like a final or even beta that would allow their use incase I wanted to get them in the future. Kind of nice to have a BIOS that supports the use of something the SATA ports are designed to use. ;)
In a bizarre way, their yanking the 1003 Final might be good though, it at least shows they pulled it quickly when they saw it was much less "Final" then they had hoped, and thus possibly will be putting a new one, or making another beta in the 1003 series that (hopefully) will both be stable and support the NCQ drives.
