Hi,
I have a A8N-Premium,
I noticed that whenever I put my computer into Dual-Channel mode, the comp would freeze. Soon I started reading up on creative form and thoughti t to be the X-FI that was cause my computer to randomally freeze. It works perfectly fine in Single-Channel mode, with the exception of X-FI Crackling. So I pulled the X-FI, enabled onboard sound, and put it into Dual-Channel mode. It still continuously locked up. I removed it from Single-Channel mode, and it ran stable with onboard audio.
I do have Cheap-O-Ramo, but I never believed that it would be an issue (not OC'ing).
Can anyone make any suggestions on how to stable out the machine in Dual-Channel mode? I have the most up to date drivers, firmware, windows updates, everything. Do you believe it is a problem with the board as a whole, or just my board? Thanks.
