three4seven
- Oct 11, 2004
I have an A8N-E mobo BIOS ver. 1013.
The bios doesn't retain BOTH settings.. but it ALWAYS retains ONE.
Attempting to manual OC the DRAM settings AND the JumperFree (CPU) settings doesn't work. Its really odd. It is either one or the other.
If I choose to manually change the DRAM config, then the CPU automatically goes back to auto. If I choose to manually OC the CPU, DRAM goes to auto. This is all in once instance without restarting.
When I set the DRAM to DDR500, the CPU (even if it was set on manual) will change back to auto and sets the CPU Freq to 250mhz. The problem is everythign else is auto (DDR Voltage, CPU multiplier, CPU Voltage, PCI express clock, CPU Frequency). Now if I set this to manual and try to change it myself, when i go back to the menu and look at the DRAM config, its changed back to auto.
Setting the CPU Freq to 200 or 250 mhz, yields DDR200 and DDR233 instead of DDR400 and DDR500. Its really silly. And because I can't change both, I can't run DDR500 with the proc at 9x250 because I can't modify BOTH the CPU AND and DRAM configs together.
The mobo basically saves whichever setting I changed last. So if I changed the CPU last, it would save the CPU manual config and the DRAM is auto. If I changed the DRAM last, the CPU will be set to auto.
You can see how this is problem when trying to OC.
In short:
Setting DRAM to ddr500 CPU clock auto at 250 x 10, (auto voltages and mutlipliers)
Setting CPU to 250x9, DDR is automatically set to DDR233 (err.. DDR250)
can't change both apparently...
am I crazy?
Thanks in advance for any help.
In short:
am I crazy?
