Hello everyone!
I am using the below config, and I still have lockups kinda often. The only thing that I can think of left to do is update the bios. Have you guys noticed any increased stability after upgrading your A8N-E bios?
and can i go back to the 1005 bios if i upgrade to a higher bios?
<<SPECS>>
Asus A8N-E revision 2, bios 1005, nvidia 6.65 chipset drivers
AMD X2 4400+
2GB (1GB stick x 2) Corsair Value Select VS1GB400C3 (in first and third DIMM slots, A1 and B1)
BFG 7800GTX PCI-E (78.03 drivers from nvidia)
Antec TruePower 550 EPS12V SSI Server-rated PSU
Maxtor DiamondMax 10 SATA 200gb (on 1st SATA channel)
Creative 52x CD-ROM (IDE Primary master)
Plextor 716AL DVD/CD burner (IDE, Secondary master)
Plextor 16/10/40A CD burner (IDE, Secondary slave)
Floppy drive
2 case fans + 1 CPU fan (AMD retail box HSF)
Windows XP Pro, SP2 (have also tried it with XP x64 Edition for a bit)
Arctic Silver 5
-everything is running at stock speeds, no overclocking.
-I have left the 1005 bios, as that seems to be the most stable which people say.
-Windows is completely updated (w/ SP2).
-I have not installed the nvidia IDE drivers.
-temps according to the bios are between 35-39 degrees (celcius). Highest i've ever seen it was 46, under load for a long time, but it hardly ever gets there.
-everything on auto in the bios except for ram which i bumped up to 2.75v.
-ran memtest86+ for about 2 hours, found no erros
-ran the diagnostic util for my Maxtor hdd, found no errors
<<SPECS>>
AMD X2 4400+
Floppy drive
Arctic Silver 5
