Did a search and didn't really see a straight answer on this. I'm basically looking to order a Big Typhoon and, you guessed it, install it on my A8N-E. Who out there has this setup, and how did it fit? Any board stress issues to speak of? I had downgraded my choice to something lighter, but after reading up on the subject I don't see much reason. I havn't seen a single documented case of a cracked board, all though I'm sure they are out there. Either way, seems like a lot of hype for the most part. If someone has a pic of the Typhoon installed on this board, I'd definately like to see that as well if at all possible. It really looks like it may block the first pair of DIMM slots
My second choice is the Ninja, all though I prefer my fan to blow onto the board, not out the rear exhaust fan.
Thanks - Matt
Thanks - Matt
