A7V8X-MX Installed ok but wrong cpu speed displayed
Well so far so good.
Got my new motherboard A7V8X-MX
Thankfully there was no problems with installing it :)
I went onto the asus website and downloaded the latest bios
http://www.asus.com/support/download/item.aspx?ModelName=A7V8X-MX
FileName: A7VM1006.zip
First time flashing bios, no problems :)
I have noticed that when i view MyComputer properties the computer description is:
AMD Athlon(tm)
1.05 GHz
512 of ram
I have AMD Athlon 1600XP and on the old MotherBoard this is what was displayed:
AMD Athlon(tm)
1600 XP
512 of ram
Can someone guide me
Cheers
Paul
Check your FSB. The A7V8X-XXX Sets the FSB back to 100 by default when you flash or clear your bios. Cause the 1600 has a 10.5 muliplier So you get 1.05GHz insted of 1.4GHz.
Thank god i didint think anybody was surfing this forum :)
I did see that in the bios.
How should it be set. Untill yesterday the only things i changed in my pc were my gfx card and any pci devices.
cheers
Paul
