Hello everyone. I'm in the process of building a new system for my brother. I decided to go with the KT-600 chipset, because it offers SATA at a lower price. Also went with an Athlon XP 2400, because it offers the most raw GHz for the buck, which he needs for video encoding.
Anyways, got the system partially built. and decided to see if it would make a pass of Memtest 86. I thought that since an XP2400 runs at 2GHz, and it had PC3200 RAM, that I could safely run at 10x200 rather than 15x133. No go. It won't even run 12x166. But it passes memtest no problems at 15x133, and I have the RAM speed set at DDR400. Really confused... even tried setting the ram speed to 266 and running 12x166 and 15x133. Only the stock speeds work.
So my question: Is there something built into this board that stops it from running at any FSB other than default? I'm disappointed... was hoping to build a strong system... 133FSB is pretty weak these days, only 33MHz higher than what he has now.
